78 450SL Front brake problems
Old May 3, 2016 | 08:34 PM
78 450sled's Avatar
Default 78 450SL Front brake problems
If I drive 35 or over and heat up the brakes by putting them on and off a couple times ONLY the left front brake will work The petal goes way down and it makes for a wild ride. I live on a dirt road so I know only the left front is working. I replaced the front caliper the other day because it was worn. I bled it and went for a ride sure that the problem was solved. Much to my dismay after a couple attempts the left front brake seemed like the only one that was working. This is quite exhilarating at 65 on the freeway when you are not expecting it.
ANY ideas would be appreciated.
Old May 5, 2016 | 08:12 PM
78 450sled's Avatar
Thanks for the reply but this was happening BEFORE I replaced the caliper .
BigPoppie
Apr 1, 2013 02:15 AM
greenl
Mar 15, 2012 05:19 PM
hallpet45
Feb 12, 2012 08:39 PM
mercedesclk0
Jun 15, 2011 04:36 PM
andrew9147
Nov 11, 2010 05:24 PM
