the heater was turning off and on off and on etc in the on postion then it quit totaly where is the heater and is there a relay i just dont no help if you can thanks
the heater motor is under glove box mine went i pushed the bottom of the heater motor up and it worked if you can wedge something between motor and casing at bottom it will work hope this helps
