420SEL Dim Lights Inoperabler
My bright lights work, but no dims. Where is the headlight relay located at? If I run a temp circuit to the yellow wire on the headlights from fuse panel the dims and brights work with the dimmer switch. Can you change the lghtswitch by removing the speedometer panel? Any suggestions? Thanks.
Don
Don
geminichrisw126
04-26-2010 09:21 AM
