380sl
i have a 380sl 1981 auto
every so often we i start it vibrates for just few second the smoothes out and runs great. it doen't seem to matter if it has been sitting or not.
i would also like to know if any one can recommend a good mechanic in the omaha ne area
thanks
thanks
If you're feeling a noticeable vibration on startup, it may be simply a misfire in 1 or more cylinders. If it smooths out quickly, a couple seconds, I wouldn't agonize over it. If the vibration continues for a lengthier period of time, you might check motor mounts.
In addition to the referrals you'll probably get here, you can also search this other site under the Nebraska tab for recommended shops near you. Good Luck, have fun with your car.
http://www.mercedesshop.com/shopforu...splay.php?f=14
Bob
Bob
YuCrew
04-14-2004 02:20 AM
