350sd climate control
Old Jul 9, 2004 | 10:25 AM
johnnyg's Avatar
Default 350sd climate control
[>:]Help,I a just purchased a 350sd and now the climate control has stopped working.The blower will not operate in manual at any speed or in auto mode.I checked fuses,removed plug going to the blower regulator,I got 1.7 volts in low speed,and 7.5 volts at high speed using a fluke,however if I use a text lite (12v) I am not getting a lite where I read the voltage,I would think the test lite would illuminate ,is this showing I may have volts but no amps? Any direction or help would be greatly appreciated,thanks.
Old Jul 10, 2004 | 09:50 AM
johnnyg's Avatar
Default RE: 350sd climate control
Update,egg on my face.I finally located the blower motor fuse,and now everything works as advertised.The location of the strip fuse was in front of the master cylinder,on the back of the sheetmetal bulkhead.It was in a black case that flips open on one side.The fuse was cracked and making intermittant contact.
zanybrainy
Jul 7, 2006 11:53 PM
mbenzer
May 17, 2005 11:44 PM
zanybrainy
May 15, 2005 12:50 AM
zanybrainy
Apr 10, 2004 03:30 AM
zanybrainy
Apr 3, 2004 12:13 PM
