300 CE oil gauge
300 CE oil gauge
I had to remove an instrument cluster out of my mbz to replace dash board light dimmer. When I was trying to put everything back together i've noticed that i have nowhere to connect oil pressure red wire. I have about 5" long red wire which sticks out of this cluster. End of this wire looks like it was soldered to something. I was looking everywhere inside dash board and couldn't find enething to coonect this wire to. Please help..... Mike
RE: 300 CE oil gauge
Hmmm.........
I am looking at my old 1989 300E cluster (out of the car)and thereare no wires hanging out the back end. You must have pulled it off something inside the dash like your post implies. Check your bundled wire connections or maybe some relay?
http://www.mercedesshop.com/Wikka/W124InstClusterI found there informations how to remove cluster. I you will remove yours can you take a look how is oil gauge connected or maybe you could do some picturesfor me? Mike
ddtbreakfast
04-21-2008 11:34 PM
mrgreek2002
05-23-2006 06:32 PM
