260e noise when starting
I have a 1990 260e. From a cold start there is a noise which seems to be from the top end for 2 or 3 seconds during which time it misfires. In about 1 0f 10 cold starts a much lighter tapping occurs which stops suddenly after about 15 seconds. I use 10/40 oil which is changed regularly.
RE: 260e noise when starting
sounds like a the fan belt, idler pulley on the mercedes belt or a failing timing belt tensioner. try to check on these things. if you still can't find the prob, bring it to a shop to have it checked. hood luck.
