2003 s430 ignition problems
Old Dec 22, 2010 | 11:28 AM
dlrbll's Avatar
Default 2003 s430 ignition problems
my 2003 s430 is having a problem. i put the key in and it will not turn to start the car. also, the key fob battery is good but the car will not unlock every time but usually does after several tries. the key usually turns after repeated attempts but i can not get the key to turn anymore. any suggestions as to what the problem is? thanks for any help you may be able to give.
Old Dec 24, 2010 | 10:01 AM
waybomb's Avatar
What about your second key? If it works fine, then your first fob has a problem.
For the fob you are using now, follow the instructions in your owners manual on changing the battery and re-synching it to the car.
Old Jan 9, 2011 | 11:59 AM
SAU's Avatar
SAU
did you get it resolved. I also have a S430 2003 model. No issues so far. I have 43000 miles on it. How many do you have?
Myran
Dec 6, 2018 03:17 PM
TopangaCLK500
Jan 13, 2012 08:28 PM
benji
Mar 30, 2011 05:34 AM
71280sl
Oct 4, 2010 11:38 AM
brantchastain
Oct 2, 2010 06:17 PM
