Ignition problem 2003 CLK500
Old Jan 13, 2012 | 11:35 AM
TopangaCLK500's Avatar
Default Ignition problem 2003 CLK500
Newbie here...I have 2003 CLK500. I insert the electronic key and intermittently the key will not turn and power up and start the ignition process. I changed the car battery that didn't fix the intermittent problem. I swapped keys, the problem still persists. Any ideas on what it might be, any suggestions?
Thanks,
TopangaCLK500
Old Jan 13, 2012 | 08:28 PM
chassis221's Avatar
try leaving the key in the ignition for a few seconds first before turning. you should hear a click type noise...almost immediatley when putting the key in. if the noise occurs after 2 or 3 seconds. you could need an ignition switch or a steering wheel lock...but could also be something else.
likki1234
Nov 9, 2014 07:10 PM
jayh
Jun 1, 2009 07:52 PM
KYU500SL
Aug 13, 2008 03:37 AM
apizzle
Jul 18, 2007 01:50 AM
