2003 E500 suspension
Need some help! The air suspension on my Eclass no longer works. It used to self adjust itself and that long gone. I brought it to the dealer, they spent 2 hours to tell me that they only found a blown fuse. I still have the same problem AND the suspension selection doesn't lite up anymore. Any suggestions or solutions?
Dom
Dom
If the center console switch is inop and no warning is on the cluster, I would suspect the switch itself. Some early lower control panel switches had failed prematurely and especially if there has ever been any kind of liquid intrusion. If the fuse for the airmatic pump was blown, you likely need a new pump and relay.
sonnyfp
Nov 3, 2010 12:04 AM
My wifes C
Aug 1, 2006 12:47 PM
