2002 C240 "Reduce Oil"
Old Sep 5, 2006 | 10:38 PM
sevegolf's Avatar
Default 2002 C240 "Reduce Oil"
Malfunction = 1, Reduce Oil. We've had this car since July 20th with no indications. Then tonight we get this indication from the computer that we need to reduce oil? HUH??? The vehicle also just came up the same day that an "A" Service needs to be done. Car has 55K. Great car, love it.... Anyone else get this display of "Malfunction"
Thanks,
Sevegolf
Old Sep 6, 2006 | 03:29 AM
snanceki's Avatar
Default RE: 2002 C240 "Reduce Oil"
3 possibilities.
1. Oil IS overfull. Check using manual dipstick on level ground. Ensure you know where the full mark is supposed to be. Check after engine has been standing for 10 mins or so if the engine is not cold.
2. Faulty oil level sender unit (in sump)
3. Spurious electronics gremlin. A RESTART usually clears.
If 1 then too much oil has been added or alternatively something else....coolant water...has been adding to the level. Check coolant level. Is it low?
Should be covered by warranty.
Good Luck.
Stuart
Srun
Feb 26, 2009 12:55 PM
zegekaf
Oct 5, 2008 09:55 PM
vip2442
Sep 19, 2006 02:25 PM
vip2442
May 6, 2006 02:06 PM
EuroKRN
Dec 27, 2005 02:14 PM
