2000 CLK320 electrical ?
Old 04-20-2006, 03:34 PM
2000clk320's Avatar
Default 2000 CLK320 electrical ?
We have a 2000 CLK320 conv. and keep getting a light malfunction displayed. I have noticed there is a problem with the brake lights. When the brakes are applied the back lights come on and so do the right front parking lights (front and side). Not the left. I cannot figure out why this is happening. Fuses are all good. Any ideas before I get it checked (which I am sure will not be cheap).
Also with the brake lights, there are 2 bulbs in each taillight (3 if you count the turn signal), the 2 on the right side light up and only 1 on the left side lights up. I swapped the bulbs and it still did the same thing, so its not the bulb.
Old 04-20-2006, 06:28 PM
Default RE: 2000 CLK320 electrical ?
remove the right rear stop bulb, press the brake. does the front right parks still come on?
normally this fault is caused by, when a double contact bulb is fitted when there should be a single contact. is there towbar wiring. basically the stop lamp wire is connected to your right side parks.
Old 04-20-2006, 09:42 PM
2000clk320's Avatar
Thanks I will check that. There is no Tow bar.
Mihle
02-08-2010 01:47 PM
gashousemouse
11-25-2007 01:28 AM
coppamilano
08-13-2007 09:26 PM
2000clk320
12-11-2006 06:19 PM
Quick Reply: 2000 CLK320 electrical ?
