2000 C280 "P0300; P0301; P0303; P0303 Misfire codes"
Old Oct 8, 2009 | 01:40 PM
Slug-Gunner's Avatar
Question 2000 C280 "P0300; P0301; P0303; P0303 Misfire codes"
Hi, I'm new to this forum, but not to automotive work. I'm a retired ASE-CMAT but NOT FAMILIAR with M-Benz vehicles and systems. About 3 weeks ago, my son was driving my ex-wife's 2000 C280 Sports Sedan, V6-2.8L (98,386 miles) and it 'bogged down' on him when he tried to accelerate into traffic. It had set the CEL lamp and I put my Equus 3160 ScanTool on it and got the DTC codes from it (P0300; P0301; P0302; P0303 Misfire codes). I erased the codes from it and drove it to check it. It seemed to drive 'normally' at low speed and under 'moderate' acceleration..... so I tried to ACCELERATE HARD and see what would happen. Once I accelerated above 3500 rpm, it started to 'misfire', the CEL started flashing, and once it went solid, the engine was in 'limp mode' (cylinders 1,2, & 3 were SHUTDOWN). I pulled over and checked my ScanTool for the codes (see above) and looked at the 'Live Data" at the time the DTCs were set - it happened at 3900 rpm. No other DTC's were set at that time, nor since that time (except a P0410 - Secondary Air-Injection System) as a 'Pending' code, but only during engine 'warm-up' period.
Over the last couple of weeks I've spent several hours reviewing older posts on this forum and another M-B forum about 'misfire codes' and many of them described MAF sensor problems being related to this. Even though I've got TWO rollaway tool cabinets with several thousand $$$ in tools in them, including a wide selection of 'security type bits', I didn't have the "5-POINT SECURITY TORX BIT" needed to remove the MAF element from its housing to clean it properly. I ordered one thru Amazon.com and finally got it a few days ago. During that time waiting for it to arrive, I've been driving the car around with my ScanTool hooked up at all times to monitor 'Live Data' and be able to record it if it failed again. It drives fairly normal, even at Interstate speeds of 70+ mph and accelerates fairly strongly.... as long as I keep the rpm below 3000-3500 rpm. I have deliberately tried to ACCELERATE HARD just before arriving home = and IT ALWAYS DOES THE SAME THING..... CEL first flashes a few times, goes solid, then engine runs like crap since the ECU shuts off the FUEL INJECTORS for cylinders 1,2, & 3. If I pull over, stop, shut off the engine for a minute, restart it again, the CEL is ON, but I can drive it again 'normally' with all cylinders firing normally (unless I accelerate 'hard' again).
I finally got the 5-point TS bit socket set and removed and cleaned the MAF element thoroughly with MAF Cleaner, reinstalled it, and then drove it around again. Everything was 'normal' UNTIL I ACCELERATED HARD ABOVE 3500 rpm. Since M-B parts are ridiculously expensive, and since it NOT MY CAR, I'm a little hesitant to start replacing parts on it without some guidance from some of you MB owners who have more knowledge of these MB vehicles than I have.
I've read these forums quite extensively and have even tried the "ECU Reset" procedures just to see what would happen. I did notice a change in the lower speed shift-points being 'quicker' and more solid and made sure to keep it below 3500 rpm until I got 'close to home'. When I tried accelerating hard again, the misfires codes and CEL returned. The 'Live Data' on my ScanTool always shows it happening between 3800-4200 rpm. Other than this, the car starts and runs quite well.... as long as you DON'T ACCELERATE HARD.
Here's one thing I'm noticing about the 'Live Data' readings I'm getting on my Equus 3160 ScanTool - the 'Advance' is always displayed as '-' (NEG) in front of the DEGREES OF ADVANCE reading. I checked this on two other vehicles and this ADVANCE displayed normally without the '-' in front of the displayed 'degrees advance' readings. Is this an 'incompatibility' with my ScanTool and the M-B ECU or what?
I've bought a set of Bosch +4 Platinum spark plugs for it and am going to replace them tomorrow and try also switching the 'coil packs' from the passenger side (bank 1) to the driver's side (bank 2) and vice-versa, just as an experiment to see if the DTC codes 'switch' with them or remain the same - this WILL CONFIRM WHETHER THE COIL PACKS ARE GOOD OR NOT. I've even purchased an AllDataDIY subscription for this vehicle, but even it hasn't provided much guidance in troubleshooting this problem since I don't have the M-B 'special tools' needed for it.
I've got to try to 'fix it' before my son returns it to my ex-wife in Atlanta or I'll never hear the end to her "B----ing about it being returned 'broken'."
I have all of the basic tools and knowledge (24 years Avionics and 40+ years auto tech background) to check anything out.... I just can't find any info as to what the voltage readings should be at various connection points to test the various suspected components properly.
Any help or guidance in troubleshooting this C280 is greatly appreciated. There seem to be some very knowledgeable people on these forums. I read about a decent $$ source for parts (near AZ, I think) but can't seem to locate it again. The local M-B dealer wants $460 for a new MAF assy, $222 for a Cam Position Sensor, and $243 for a Coil Pack.
Old Nov 6, 2009 | 07:53 PM
99frc's Avatar
This is the same exact problem I'm having on my 2001 CLK 430. Following this thread for advice...
Old Mar 1, 2011 | 11:52 PM
Senorking's Avatar
I'm having this exact same problem, can't figure out what is wrong. Did you ever solve the problem?
Old Mar 2, 2011 | 03:21 PM
Arrow
TO ALL CONCERNED READERS:
Spark Plugs, MAF and Camshaft Sensor were replaced without any change in operation of the vehicle.
I finally had the catalytic converters checked at a local exhaust/muffler shop (using the 'pressure test method of drilling a hole at the front and rear of the CATS and check the DIFFERENCE IN PRESSURE). The test results indicated that the CATALYTIC CONVERTERS WERE BAD/RESTRICTED and were causing EXCESS BACK PRESSURE causing the misfire conditions.
I told my ex-wife what the results were and that she would have to pay the cost of the repairs (about $750 each for the catalytic 'after-market' replacements). It would have cost about $4500 to do it at the M-B dealership. They were all (4 ea) replaced with TWO after-market units for a cost + labor of $1600,
My review and research of several different M-B Forums disclosed that the M-B catalytic converters BECOMING DEFECTIVE/CLOGGED at around 100K miles IS QUITE A COMMON OCCURRENCE. You can have your catalytic converters checked using the above 'pressure test method'. The TWO small holes drilled to install the pressure test reading sensors are plugged using stainless steel plugs made just for these 'pressure test' purposes.... so if the 'pressure test' checks the CATS as "GOOD", the exhaust system IS NOT AFFECTED BY THE HOLES THAT WERE DRILLED IN THEM.
Hope this helps some of you with similar symptoms to CHECK OUT before spending hundreds of $$$$ on unnecessary parts in the ignition and intake air systems trying to solve this MISFIRE CODES problem.
Old Mar 24, 2011 | 09:21 PM
Senorking's Avatar
Thanks for the reply, I had a different problem but I did check exhaust backpressure after reading your reply, and I was able to rule out cats.
For all others seeking information on this problem, I did a write up on my experience here:
https://mercedesforum.com/forum/merc...98/#post148215
Adam Joy
May 18, 2015 09:40 AM
mercedesdieselpetr
Mar 26, 2014 04:23 PM
mnoll406
Apr 23, 2010 05:43 PM
Slug-Gunner
Oct 8, 2009 01:37 PM
resistro
Jul 2, 2009 08:41 AM
