1999 c230 komp sunshade removal
Old Jul 13, 2009 | 11:56 PM
dustyr's Avatar
Question 1999 c230 komp sunshade removal
I have a 99c230 kompressor. The sunroof sunshade fabric has come loose from the panel. How do you remove the panel for repair? New member, thanks for your help. Dusty
Old Jul 14, 2009 | 06:47 PM
chassis221's Avatar
glass needs to come out first. open the back of the roof to tilt, then inside the car there are the accordian rubber things on the sides of the sunroof, you might not have these on your car accually. , pull them off then youll see 3 screws on either side, torx screwdriver youll need, pull out glass. then slide the shade forward and then push in the plastic/meatl tabs that slide along the track and pull out the shade from the top of the car... pay attention to the postion of the sunroof glass to the roof before removing it. cause you can get wind noise and water leaks and roof binding if you dont get it close to what it was.
XLordShortyX
Mar 24, 2007 03:49 AM
snowy
Feb 25, 2007 02:16 AM
snowy
Feb 24, 2007 07:58 PM
rdemirkan
Feb 26, 2006 05:30 PM
XLordShortyX
Apr 25, 2005 12:41 AM
