1995 S-320 rear right window blues
Old Apr 25, 2009 | 11:52 AM
German Roots's Avatar
Default 1995 S-320 rear right window blues
Hello All,
I am a new member on my 2nd Mercedes and I have a question that I need guidence on. Last week there was some hesitation on my rear window to roll up when using the switch @ the drivers seat shift area. After 2-3 tries it rolled up. This morning I rolled the window down all the way and the window is now stuck there. I can hear the motor turn on in the door (while using door or master switch) and the window moves about 1 cm. Could it be a blockage, toasted gearing in the motor or time to give it up to my mechanic and suffer the hit on my checkbook? I am not sure it makes a difference but the windows are double pane.
Thanks, Chad
Old Apr 25, 2009 | 12:03 PM
chassis221's Avatar
99 % of the time its the regulator that lifts the window. operate the window with both the front and rear switches to make sure.
Old Apr 25, 2009 | 12:11 PM
I tried the front and rear switch and both times the window engine could be heard trying to move the window. If so, is the regulator (electric motor) toast in most cases?
Old Apr 25, 2009 | 01:37 PM
chassis221's Avatar
usually the motor is fine but the regulator fails. it could be a motor if when you hold the window switch and the motor is not running. if you hear the motor running then the motor is probably ok. regulator is the mechanical device that guides the window up and down...it not the motor. you should remove the door panel to inspect it for yourself.
Old Apr 25, 2009 | 02:28 PM
I will remove the panel and inspect the regulator. Thanks for the advice.
TamC280
Jul 21, 2010 06:25 PM
tvernon-kell
Feb 17, 2009 07:17 AM
mjovolt
Aug 14, 2006 12:18 AM
andrehalito
Jul 4, 2006 03:03 PM
Royal
Jan 11, 2005 03:46 PM
