1994 Benz E320 funny idling.
Old May 18, 2006 | 04:48 PM
ajh_28's Avatar
Default 1994 Benz E320 funny idling.
My mother's '94 Bnez E320 seems to be having a idling problem. When the car just sits in either park or drive, the rpm gauge just goes up and down over and over, from about .5 rpm to 1-1.5 rpm. Then when you step on the gas to go, it chokes for a bit, the power lags, and finally it just bursts out and drives off. Any ideas what could be causing this problem?
Old May 18, 2006 | 05:46 PM
houston300sel's Avatar
Default RE: 1994 Benz E320 funny idling.
Have you gotten any information on your question ? I have a '90 300SEL which does exactly as you described...
Old May 18, 2006 | 10:03 PM
ajh_28's Avatar
Nope, nothing yet. A dude at a local certifed Mercedes dealership said it might be a vacuum problem but that just doesn't sound right to me.
Old May 19, 2006 | 08:44 AM
diamond geezer's Avatar
had the same problem with my previous car(e220 124 series)...it was soved by fitting a new AIR FLOW METER but part was expensive here in u.k...hope this helps
Old Feb 7, 2007 | 06:04 PM
nabiil's Avatar
Hi ajh28, my C180 is giving me the exact same problem. Any luck on gettingthe problem fixed?
Old Feb 8, 2007 | 04:00 AM
bazzle's Avatar
Remove MAF. Spray insert LIBERALLY with MAF or contact cleaner, Shake dry.
Bazzle
Old Feb 8, 2007 | 06:39 PM
gasdude's Avatar
As Bazzle said,
You have hunting idle, a prime indicater of a dirty MAF.
Either replace or clean it and you should be OK.
Best,
Ron
nopcbs
Dec 31, 2012 05:43 AM
craigndee
May 19, 2008 06:39 PM
craigndee
May 14, 2008 11:12 AM
siccmade
May 12, 2006 03:06 AM
COFIELD
Oct 28, 2004 11:40 PM
