1990 300CE-24 Stumble idle after start-then smooth
Old Mar 8, 2005 | 07:09 AM
ddjac's Avatar
Default 1990 300CE-24 Stumble idle after start-then smooth
I have a 1990 300CE-24 200,000km, clean, perfect - except that hot or cold, warm or cold weather, intermittently, car starts immediately upon cranking, then stumbles - sounds as if it will stop (has stalled), runs at slow RPM for 3-6 seconds, then resumes normal slightly quick idle.
If I switch it off & re-start, it will start normally.
Leave it for 10-15 minutes, then stumble idles again per above.
Other symptoms:
intermittent sluggish take off from stop start - hesitates for a second while depressing accelerator - then launches suddenly.
engine stumbles at high revs (4500rpm) while still accelerating at high speed.
I am using high octane premium fuel only. The fuel consumption seems OK, although I've only had the car for a week and don't really know what's normal.
Mechanic has:
1. replaced idle air control valve (tested old one and said it was knackered?)
2. new spark plugs
3. new air filter
4. oil change & new oil filter
5. additive put into oil to free up sticky valves (possible cause?)
6. added injector cleaner & other fuel additive to absorb possible condensation in tank
$1000 later, problem has not gone away, and seems worse.
Any thoughts please?
Old Mar 8, 2005 | 07:45 AM
sleepwalker's Avatar
Default RE: 1990 300CE-24 Stumble idle after start-then smooth
problem ranges from air flow meter sensor, electrohydraulic actuator and fuel system.
Old Mar 8, 2005 | 08:48 AM
ddjac's Avatar
Thanks sleepwalker.
What is the electrohydraulic actuator?
Do you think from my description that the problem could be a leaky injector(s), noting that the idle problem is most apparent after the car has been sitting around for a while.
That is what the mechanic is checking into next. Is this an easy test, is there a schroeder valve on the fuel rail that can hook up to a fuel pressure gauge and check for fuel pressure loss after pump has shut down.. or is it not that simple to check for leaky injectors? I would hope that the mercedes "expert" working on my car knows how to do this.
It just seems like alot of trial and error. I was hoping to get it diagnosed and fixed quickly without throwing more parts at the car that it doesnt need.
Old Mar 8, 2005 | 09:40 AM
snowisgr8's Avatar
doesn't that car have plug wires? sounds like a wire with high resistance, only fails under load. check for burn marks around the plugs and on the wires.
Old Mar 9, 2005 | 06:13 AM
ddjac's Avatar
Wires were resistance checked be mechanic & checked out OK, so he tells me.
Injectors checked today and found to be OK.
Any other ideas, anyone had a similar problem?
ChiefRider
Dec 18, 2011 09:53 PM
steve00
Apr 26, 2010 11:48 AM
RonnieB
Sep 27, 2007 08:34 PM
tuk27
Sep 18, 2006 12:45 PM
maina
Oct 4, 2005 06:45 PM
