1987 560 SEL front right clanking sound
Old 04-05-2005 | 04:39 PM
hawkeye's Avatar
Default 1987 560 SEL front right clanking sound
When I drive over a bump there is a clanking sound around the front right tire. We checked all around there to see if anything was loose but found not a thing. Took off the tire and everything looks good. I took it back to our tire shop and they checked the shocks which were just replaced. Look under the hood to see if anything was loose but all looks good. All this and we still have the same noise. Does anyone know what this could be.. Thanks, Janet
Old 04-07-2005 | 01:31 PM
Randy's Avatar
Default RE: 1987 560 SEL front right clanking sound
sure it's not a brake reaction rod joint worn? If so, repeated light tapping of the pedal when moving slowly will reproduce it. I would describe it as more of a clunk, though.
Possibly a broken stabilizer bar?
Old 04-10-2005 | 05:25 AM
SL600_Cruzin's Avatar
Could also be the control arm bushings. The coil spring will tend to hold it stable while you are looking at it etc... and everything will appear normal unless you look directly at it. But when you hit a bump, it's enough to jar it to make the noise you've described above.
hope this helps,
cheers
gerdub
02-08-2012 03:23 PM
anke_nielsen@yahoo.com
01-31-2012 12:00 AM
selman
04-20-2010 06:29 PM
hawkeye
04-05-2005 04:43 PM
korte4260
04-01-2005 04:27 PM
Quick Reply: 1987 560 SEL front right clanking sound
