1986 300e speed sensor resistance value
Old Dec 19, 2008 | 07:11 PM
kasparov747's Avatar
Default 1986 300e speed sensor resistance value
i have a 1986 300e that the abs light has come on after i get up to and over 15mph. the light stays on until the ignition is off. i took both front sensors out and cleaned them as they had a lot of small magnetic particles on them. i then checked the resistance at the connector under the hood. the drivers front sensor read 1050 ohms and the passenger side sensor read 984 ohms. the drivers side read 0.4 volts when i turned the rotor but i didnt do that for the passenger side. i hope someone can tell me if the resistance values are within specs or are they not where they need to be and maybe if the sensor is bad. thank you for your time and have a nice day.
bstar
Mar 8, 2008 02:32 PM
stevel
Jan 16, 2008 03:06 PM
usedcarjunkie
Mar 5, 2007 08:16 PM
benz300e
Nov 25, 2006 07:09 PM
benz300e
Nov 24, 2006 09:24 PM
