1985 300SD will not start!!
Old Jul 6, 2007 | 11:02 PM
bigdk's Avatar
Default 1985 300SD will not start!!
I need some help with this one! My 1985 300SD will not start, If I jump the starter with the key on it will run great, but when I try to start the carwith the key it will notengage the starter.I changed out the iginiton switch, vacuum lines and all but still will not start. Any advise where to look next??
Old Jul 12, 2007 | 01:24 PM
tessshoup's Avatar
Default RE: 1985 300SD will not start!!
I had something similar happen to me a couple of months ago in my 1995 C280.I was told it is the Safety Neutral Switch (somewhere under the gear shifter). I was advised that if the car doesn't start in park - to put it in neutral. Works fine for me!! Hope this is your answer.
Old Jul 12, 2007 | 05:11 PM
NAZ's Avatar
NAZ
check the gear selector inhibetor switch ,its attched on the selector lever,on the left side underneath the car its big plug connector with 4 pins ..............
benz300sd
Jul 12, 2014 08:19 PM
killaimdie
Sep 22, 2010 07:35 PM
bjcatt
Oct 20, 2009 11:41 AM
DieselRepair101
Apr 24, 2009 07:25 PM
1fastredsc
Dec 3, 2007 08:48 AM
