1982 300SD door panel removal
Passenger rear window dropped, not now connected to motor or regulator.
Question: How to remove door panel to get at problem. Have already removed the 2 screws on chromed latch cover (slanted rear of door contour). Have also removed the two screws on arm-rest and plastic lock actuater ****. Small end of arm rest enters control panel ( window switch and door latch handle area) but cannot release arm rest from door. Seems like the door panel is being held in by (1) the small or top end of arm rest and (2) the simulated wood and black plastic control panel. What is the trick to releasing these without breaking these plastic parts? Also what is most likely to be the problem with the rear window? Broken part? The rear motor still operates. New to the forum. Would greatly appreciate any help!
Thanks,
DR
Thanks,
DR
