1980 450 SL Bosch carburetor
I pulled off the air cleaner and in front of the injector lines and behind the "pot"? there's a small spring loaded vertical tube that is open ended.
I found what appeard to be a plastic cap wedged by the driver's side valve cover.
Should this tube be open or is the cap I found to be put on the open tube?
Thanks for any help on this.
Roger "B"
Roger "B"
jomerc
02-04-2013 09:27 AM
1980, 450, 450sl, benz, bosch, carb, carberator, carbeurator, carburated, carburator, carbureted, carburetor, forum, mercedes, sl
