1979 300CD, won't start
Old Mar 2, 2010 | 07:18 AM
dwnwtly's Avatar
Default 1979 300CD, won't start
Reamed and Installed new glow plugs and wires. Changed the fuse, still won't start. Any ideas?
Old Mar 2, 2010 | 08:13 PM
mbz connexion's Avatar
The weathers cold, I'd check compression. I guess while the glow plugs were out you could have checked compression so you could eliminate that from your diagnostic procedure.
Anyway what I'd check at this point.
With a test light, do you get power to all glow plugs?
How long does it take for the glow plug lamp to go out?
Crack an injector line loose and see if you're getting fuel.
If those are good, get out your compression guage.
Have you verified engine/valve/injection pump timing?
dwnwtly
Nov 17, 2010 09:54 AM
dwnwtly
Oct 8, 2010 10:10 AM
dan4th83
Oct 22, 2007 05:17 PM
ir1sh 028
Jul 23, 2006 10:51 PM
zyl8tr
Jun 13, 2006 06:31 PM
