190e. 1800 heater problame
Check the heater valve, referred to as a mono or duo valve. You will have a mono valve. It is the heater valve that controls coolant flow to the heater core. Over time, the insert seal tears and coolant bypasses, allowing heat at all times. Chances are that it is the insert (if avail separately) but the coils on the valves are known to occasionally go bad too(complete valve). Easy way to check it is to pinch off the outlet of the monovalve (inlet of heater core) which cuts off coolant to the heater core and see if it gets better. If it cools down, that will likely be the problem.
lancemb
Dec 31, 2007 07:59 AM
ninja_van1sh
Aug 11, 2007 08:15 PM
