03 C230 "spurrtering" at idle
Old Sep 28, 2007 | 03:23 PM
benzojatt's Avatar
Default 03 C230 "spurrtering" at idle
My 03 c230 only has 26,000 miles on it but is out of warrenty due to years. Today, it started "sputerring" at idle and seems like its about to turn off. Dealer said it most likely is a vacuum leak and if its what they think, will cost $700 to fix!!!! Any ideas on what I can do to check the car out myself or any ideas at all???? THanks!
Old Nov 25, 2007 | 12:16 AM
xlntech's Avatar
Default RE: 03 C230 "spurrtering" at idle
I'm having the same problem on my '03 C230 (51k), I took it to my local Mercedes dealer and they told me it was an oil leak. Oil dripping on
a idle sensor and the repair would cost $1080 ??? I don't quite believe that and will be bringing it to a different dealer to get a second opinion.
Have you fixed yours ? I wonder if anyone here knows what's the solution is or where to have it fixed for a reasonable price.
Thanks,
xlntech
Old Nov 25, 2007 | 02:43 PM
NAZ's Avatar
NAZ
the fault on your is fructured vaccum pipe,its plced under air box its from engine brether to inlet monifold,very common there is a modified pipe to replace on this model engines..........
LORE BENZ
Aug 29, 2017 06:49 PM
mikecruz
May 12, 2010 09:48 AM
bug
Jul 20, 2008 03:05 AM
paypaboi
Apr 2, 2007 08:46 PM
lcs164
Jan 23, 2007 11:27 PM
