Exterior Talk about your rims, body kits, lighting effects and other exterior mods here.
w211 wheels on w210
Old Oct 16, 2006 | 05:32 PM
chicomerc's Avatar
Default w211 wheels on w210
Hi, I have acquired a set of 16" w211 wheels and want to know what effect they will have if fitted to a w210 MY 12/01.
The original alloys are 71/2J the w211 are 8J.
The w210 offset is ET41 and the w211 is ET36.
Will this make any difference to the car - if so what?
Hope someone out there has some useful info.
Thanks.
Old Oct 29, 2006 | 12:37 AM
raymond~'s Avatar
Default RE: w211 wheels on w210
Mercedes does not recommend this, of course. Width wise, I dont see any red flags, though your info is incomplete. "fit" includes tire and wheels and all specifications. also do not know exact wheels you have as it is important to know the lug design. custom bolts may be needed, depending on a variety of factors.
Old Oct 30, 2006 | 12:29 PM
mbz300sdl's Avatar
Well if you have them than put them on the car if nothing rubs and the bolts are correct you are good to go. MOST German cars lug pattern is 5*112. But that might not be true for all but those are both 5*112.
Old Oct 30, 2006 | 05:17 PM
chicomerc's Avatar
Thanks for the feedback.
All info I have is that when fitted to w211 they use 225 55 16 tyres (not 215 55 16 as 210).
I could use 225 50 16 and not alter the speedo reading much.
Old Oct 31, 2006 | 06:32 AM
raymond~'s Avatar
the W211 rim is designed for use with 14mm lug bolts with 14mm radius ball seat.
your W210 uses smaller 12mm lug bolts with 12mm radius seats.
bottom line: if you use your existing bolts, you'll lose much lug seating as contact point. chances are that the W211 rim will have much less thickness at the lug....from ball seat to mounting surface, thus requiring a shorter bolt.
in other words, dont do it unless you're going to hunt down custom/conversion bolts which use 12mm diameter bolts with 14mm ball seat.
did this last year, fitting an AMG from a W211 2005 E55........to my W210 99 E320.
http://i13.tinypic.com/44afiiw.jpg
regarding tyres - try using this calc engine to determine % of allowable error
http://www.miata.net/garage/tirecalc.html
Old Nov 4, 2006 | 07:34 AM
chicomerc's Avatar
Thanks for the info Raymond.
Much appreciated.
Old Nov 4, 2006 | 07:39 AM
chicomerc's Avatar
Raymond.
Can you advise where you got your bolts from?
Thanks.
Old Nov 6, 2006 | 01:30 AM
raymond~'s Avatar
https://mercedesforum.com/m_43082/tm.htm
that should give you the needed info. if you have more questions, feel free to PM me
Minesthechevy
Aug 12, 2015 12:26 AM
Schnezza
May 11, 2008 12:47 AM
bcmayo
Mar 24, 2008 08:39 PM
BenzoDJ
May 14, 2006 08:58 PM
raymond~
Apr 8, 2006 07:41 PM
