Exterior Talk about your rims, body kits, lighting effects and other exterior mods here.
Remove Grease from Exterior
Old Mar 20, 2005 | 09:57 AM
Splotto's Avatar
Default Remove Grease from Exterior
Hello:
I noticed the other day that a glob of lubricating grease has plashed onto my passanger rear panel behind the wheel. I tried getting it off with a dry towel with no success.
I went through my fav carwash and no luck.
Of course I am hesitant to use any cleaning material until I am sure I won't do more harm then good.
Any ideas?
Splotto
Old Mar 20, 2005 | 12:07 PM
Patrick's Avatar
Administrator
Default RE: Remove Grease from Exterior
i would buy a bag and tar remover...and follow the directions exactly...[8D]
Old Mar 20, 2005 | 12:17 PM
Splotto's Avatar
ORIGINAL: Patrick
Hello:
Thanks. Any brand recommendations?
Splotto
Old Mar 20, 2005 | 12:37 PM
Lugnut's Avatar
I doubt it's bad enough to risk using a bug and tar remover.
Try some warm soapy water and turn the towel often as you wash so the grease doesn't just smear. Use something a little stronger than car wash soap, like a dishwashing soap such as Dawn.
Old Mar 20, 2005 | 03:28 PM
C280 wizard's Avatar
WD40
Old Mar 20, 2005 | 05:14 PM
Lugnut's Avatar
WD40? A stick of dynamite will get it off, too. But, you gotta ask yourself...
Old Mar 20, 2005 | 08:50 PM
MBenzS600's Avatar
I usually just get a brush with hard bristles (Not to hard because it will scratch) and just brush it off using hot water and a sponge as well.
Old Mar 20, 2005 | 10:00 PM
Lugnut's Avatar
It's on his paint. Using a stiff bristled brush would be a mistake.
Old Mar 21, 2005 | 11:12 AM
  #9
MBenzS600's Avatar
OH it's on the paint job??? WHOA Nevermind. I usually use a brush on the build up of tar right behind my tires(the place where a mud flap SHOULD be)
astrobike
Apr 7, 2015 10:26 AM
car5car
Aug 22, 2011 09:17 PM
Lindy
Oct 8, 2005 05:55 PM
motan_misto
Feb 11, 2005 12:16 PM
Buck
Apr 25, 2004 02:01 AM
