The Winter Blues
Old Jan 10, 2005 | 10:31 PM
Royal's Avatar
Default The Winter Blues
Hey guys,I'm one of the newbies around here and with my new Benz all together. My problem is this,I'm stuck. My baby,a 1982 Turbo Diesel 300se,is refusing to get up. At all. It ran beautifully in the summer though when the winter set it,start up became a no show. I took it in for repairs,the glow plugs are fine(As was my first concern) and he replaced a few hoses,yet after a week... it won't start. The electrical system seems alright but when I turn the key,it does nothing. Absolutely nothing. At first it sounded like it just didn't have enough power to roll over the engine,then it got weaker...and weaker... now it's dead. My thoughts were circling around the Starter,any other ideas for a clueless newfound Benz lover?
Old Jan 10, 2005 | 10:43 PM
pberku's Avatar
Default RE: The Winter Blues
There are several possibilities.
a) Corroded and or Defective Starter wiring/ground,
b) Defective Starter
c) Weak Battery or Charging System
d) Valves way to tight. Need to be adjusted.
e) Coolant leaking into the Cylinders, preventing the engine from turning over. This could be caused by a cracked head, or head gasket (Unlikely unless you are constantly loosing coolant, for which you can not find an obvious cause.)
Check the easy ones first.
That's about it
By the way, I don't think you meant to say that your car is an '82 300SE Turbo Diesel. More likely its a 300SD, or 300TD. Which one is it?
Phil
Old Jan 10, 2005 | 11:06 PM
sleepwalker's Avatar
Old Jan 11, 2005 | 03:46 PM
Royal's Avatar
Oh man,I can't thank you folks enough! Actually,it's a 300SD,lack of sleep and stress helped my spelling veer off track there,heh. Now I actually have a place to start looking,which is exactly what I was looking for. Once more,thanks a thousandfold!
alexanderlintern
Nov 9, 2007 05:45 AM
gianigreco
Nov 8, 2006 12:32 PM
gianigreco
Nov 8, 2006 12:21 PM
andrehalito
Jul 7, 2006 09:01 PM
andrehalito
Jul 4, 2006 03:03 PM
