W210 - 98 E300TD OM606 - no fuel at injectors
My 98 E300TD quite running - I am getting power to glow plugs - I am not getting fuel out of loosened injector B nuts - I feel and hear the click of the fuel shut off valve (FSOV) - then by taking small bolt out of top of fuel filter housing and with ignition key turned on applying air pressure from air compressor to fuel system via gas tank inlet - fuel seemed to push through - with it leaking out of top of pre-filter connection now it previously had started in this manner but now it will not start? What is the best way to bleed the fuel system and what is the best way to tell if it is the injection pump itself that is not providing high pressure fuel to injectors? Is there a lift pump involved in this system? Even if not outwardly leaking can poor IP valve body seals cause no output? Does anyone here on forum have or know of an injection pump I can buy and or send to reputable someone for rebuild - is the pump an OM606 with part no 6060700601?
I hope I can remove and then properly install and time it!
Any info - suggestions - advice - is well appreciated!
Magic Mike
Oct 29, 2010 10:24 PM
