W123 brake bleeding
Old Jun 18, 2020 | 07:37 PM
Sweet Benz's Avatar
Default W123 brake bleeding
I had two dragging calipers so I replaced them all with rebuilts. That went fine, but I’m getting no pressure / fluid coming out at all on either rear caliper... Any thoughts? Thanks, SB
Old Jun 19, 2020 | 11:35 AM
JustAghost's Avatar
Two dragging calipers is not coincidence, especialy if they were both front or both rear. I would replace the master cylinder.
Old Jun 19, 2020 | 12:11 PM
Sweet Benz's Avatar
Thanks. Hey, do you know if the master cylinder is a dual bowl? That is, if the front brakes are working and fully bled but the rear brakes are not, can I drive it to the shop?
Old Jun 19, 2020 | 01:38 PM
JustAghost's Avatar
No. Driving with partially functioning brakes is not safe.
Old Jun 19, 2020 | 02:05 PM
Sweet Benz's Avatar
Ugh... the local independent Mercedes shop diagnosed the problem, but wanted a small fortune to replace the calipers. I’m sure they’d have found that they needed to replace the master cylinder once that didn’t solve the problem, but since I did it myself, the thing is now beached and undrivable at the bottom of my driveway. Thanks for the help though.
Old Jun 20, 2020 | 11:55 AM
JustAghost's Avatar
Small fortune? They're literally 15 minutes a piece to swap, including R&R of the wheel and brake hose. Maybe add another 20 minutes for flushing the brake fluid. At $150/hr shop rate, it shouldn't have been more than $150 labor to replace the rear calipers and bleed them.
Old Jun 20, 2020 | 02:11 PM
Sweet Benz's Avatar
Yeah, that independent repair shop wanted $1200. Just not worth it…
Old Jun 20, 2020 | 11:01 PM
JustAghost's Avatar
lol, you could buy a parts car for each caliper and throw away the rest of the cars for that!
Old Jun 21, 2020 | 03:00 PM
  #9
Sweet Benz's Avatar
Alright, so I broke down and bought a hand vacuum bleeding kit from the parts store and I’m pulling nothing but air coming through the hose (that is, I have the thing setup upstream of the caliper)... The reservoir is plenty full, so do I have a bad seal somewhere around the master cylinder?
Old Jun 21, 2020 | 03:33 PM
  #10
Sweet Benz's Avatar
Could a pinhole leak in the car’s vacuum system (not the hand pump) contribute to the difficulty in bleeding the rear brakes? The front brakes both bled fine...
Serenity
May 10, 2012 12:47 PM
usedcarjunkie
Mar 10, 2007 05:50 AM
chuling
Feb 25, 2006 10:43 AM
inssane3gt
Jan 25, 2006 12:36 AM
greasepit
Aug 23, 2005 03:01 AM
