very choppy idle
Old Jun 3, 2011 | 05:31 PM
thesnafu72's Avatar
Exclamation very choppy idle
my 1980 300d has been giving me grief lately. as i pull up to a traffic light, after a couple seconds the engine starts shaking at a much higher level, and then shuts off. someone suggested it was the fuel pump, but i need a second opinion. what say you ?
Old Jun 3, 2011 | 07:19 PM
DetroitFlyer's Avatar
Default Maybe fuel
I had similar symptoms in my 82. Refilled with Speedway fuel and all is well.
Old Jun 4, 2011 | 02:19 PM
thesnafu72's Avatar
what's speedway ? is that a brand or higher octane ?
Old Jun 5, 2011 | 12:52 PM
Speedway is Marathon Oil's brand. Ran poorly on BP's diesel.
Old Jun 6, 2011 | 03:28 PM
Default Water?
The Speedway station I normally use is on a high traffic road. The BP station is on a much less traveled road. We had a VERY wet spring here in Detroit, (second wettest on record). I wonder if the BP station had some water in their fuel tanks? I mean it was like I flipped a switch. When the BP fuel was gone and I refilled with my normal Speedway fuel the car ran smooth again. I agree that is probably has little to do with the brand. Maybe it was just water in the fuel...?
Old Jun 7, 2011 | 03:27 AM
thesnafu72's Avatar
ok well say it wasn't the fuel itself.. my car will start but when i try to put it in gear it just shuts off. if i rev the engine though, the car stays on. wtf !?!
Old Jun 10, 2011 | 08:53 AM
oldrebuiltdodge's Avatar
If the car starts easily it isn't air in the lines. If it will run ok at higher speeds, it probably isn't the delivery pump, or the injector pump. That leaves fuel quality, or a dirty fuel filter, or maybe a combination of both
Old Jun 19, 2011 | 10:08 PM
ocmechanx's Avatar
Could the idle just be set too low?
robfrey
Jun 29, 2012 08:33 AM
chrisbassman
Aug 19, 2010 02:33 PM
paintarola
Mar 20, 2005 01:38 AM
unclegreaser
Dec 30, 2004 10:54 PM
nitro994
Oct 28, 2004 01:03 PM
