TURBO SQUEAL!!
So my turbo has started squealing like MAD...
I was thinking I could just stick another used on in there.. but I was wondering, is there another replacement I could use, that spools a bit faster?
I dont really need more boost on the top end, but getting it up to PSI quickly would be nice...
or any other thoughts on non-stock replacement turbos?
and im not opposed to installing an EGR gauge if needed ;^)
BTW..
EGR blocked
No Cats
Straight pipe exhaust (no muffler)
ALDA removed
325k miles..
thanks in advvance!
-Dan
82 300 SD5 cyl Turbo
BTW..
EGR blocked
No Cats
ALDA removed
325k miles..
thanks in advvance!
-Dan
So another question.....I'm pretty sure Ialready know the answer.. but what happens if you run this motor without the turbo? assuming a person has installed the correct bypass piping?
thanks
-Dan
thanks
-Dan
Running like that wont damage the engine with lower input pressures or anything?
Well I guessI know of people (grandparents) that drives these carsin such a way that they NEVER spool the turbo...
thanks for the info!
