Transmission pressure
Old Aug 11, 2006 | 08:50 PM
rsmartin's Avatar
Default Transmission pressure
Can anyone provide the proper transmission pressure per the technical data manual for '84 300SD? Or is it OK to just adjust the T key until it feels OK. I've checked the vacuum to the valve on the injection pump and set it to 6.5 with 10MM distance from the stop. Also, checked all throttle linkage lengths per service manual. Replaced the little fingers on the vacuum switches on top of the valve cover too. Adjusted bowden wire so there is very very slight slack so the upshift occurs around 3000 rmp under moderate acceleration.
My '85 300SD shifts so nice and this 84 shifts OK but pretty slow to downshift unless you press the pedal all the way down, just before engaging the electric downshift switch.
mr2weenie
Jul 10, 2006 04:21 AM
T Lindau
Dec 30, 2003 05:53 PM
zeaq
Dec 29, 2003 03:06 PM
benzuk
Dec 6, 2003 01:01 AM
chazola
Nov 12, 2003 01:04 AM
