strange sound at rear axle
I have the same problem in my 1982 300D T. It whines when accelerating, but stops when approaching 70MPH, and is very quiet at 80MPH and above. The drive shaft is in the shop getting the middle bearing replaced, etc. Although the flex disc's look okay, I'll also replace them. However, I still strongly suspect it's the differential. So far I was quoated $1200. to replace it. However, the mechanic said there is little danger of it siezing, so I intend to finish some other upgrades before I tackle that very annoying whine.
Best wishes,
charlie
Best wishes,
charlie
Hi
So if the rear diffrencecial is not leaking that means there is nothing wrong with it. Right?.Because its not leaking. And also when i jack up the car, put the gear in netural and turn the tire left to right and i hear a ticking sound, the sound is comming from u joint in front near the transmission, could that cause the sound? or is it normal.
Thx
Thx
Air Imports, University Place, WA replaced ujoints, bearing, support and flex disks. They also balance the shaft by putting the car on a rack, attaching a hose clamp to the drive shaft and periodically marking, then moving the clamp until all vibration was dampened. It solved the "Clunking" sounds and vibration, but it still has the "whine."
Air Imports said the whine is definitely coming from the diffential. They'll install a used differential for $850.
well folks;
here is an update about my car; the noise that I get from the back initially started as a click when I go from reverso to drive; or even if I was going in drive; a month later the noise was accompanied with a grind noise all coming from the back. I took the car to two Specialized MB mechanics; and they both agreed that the noise was the differential; they both checked the flex disks ( front and back); the drive shaft bearing; and the axles; and they all were Ok. Now I am left with no option but to replace the diff; and guess what; the noise did not go; that was a blow to nearly $2000; tomorrow I am taking the car to the dealership; even though in the past they guessed every thing; I am hoping they have a solution to my car. If any one has any ideas please to let me know ( my car is a 1995 300 E Diesel).
thanks
thanks
