sprinter van
Old Nov 12, 2010 | 04:43 AM
davidbrydson's Avatar
Default sprinter van
i have a sprinter van 1996/7 automatic 412d desiel. the ecu thinks the van is always in park or neutal and wont rev past 4000rpm when you are in gear and cannot find the problem i have replaced all the sencers and replaced all the fuel line pipes and still have the problem could anyone send me a wiring diagram of the sprinter van or know where i can buy one ?
Old Nov 12, 2010 | 10:24 PM
Diesel9112's Avatar
I am going to make a guess. On most vehicles with an Automatic Transmission there is a Neutral Safety Switch. The normal function of that switch is to keep you from starting when the Engine is in one of the Drive Gears.
However, such a switch could also be used to tell the Computer if you are in Park or Neutral. So, if the switch is bad I could see that as being a possible cause of the problem.
Again on other vehicles if the Shifter Linkage Bushings are worn they will not move the switch correctly.
I am also thinking that there must be a Forum for the Dodge vehicles that might have more info.
eagle-co94
May 6, 2013 12:38 PM
MIKE"N"HELEN
Dec 10, 2009 03:08 AM
newtodiesel
Apr 12, 2009 01:51 PM
Russ208d
Jun 28, 2007 04:07 AM
Robinhood
Sep 10, 2005 09:46 PM
