Smooth idle when cold outside? Rough when hot
Old Oct 3, 2005 | 12:59 AM
maina's Avatar
Default Smooth idle when cold outside? Rough when hot
My 83 300SD Runs smooth as silk when cold outside and cold engine. As the temperature outside increases than so does the rough idle. To break it down here's how it runs.
cold (below 50 degrees)/ cold engine = smooth idle
cold (below 50 degrees)/warm engine = slightly rough
warm (above 70 degrees)/cold engine = slightly rough
warm (above 70 degrees)/warm engine = very rough
Any suggestions?
Old Oct 3, 2005 | 09:24 PM
Laterthatsameday's Avatar
Default RE: Smooth idle when cold outside? Rough when hot
Maybe motor mounts.
Old Oct 3, 2005 | 10:34 PM
maina's Avatar
Thanks. That was the first thing I did. I also replaced the engine shocks too while I was at it.
Old Oct 4, 2005 | 06:45 PM
If it's an even shake when running rough warm I would say the rack stop on the back of the injection pump needs adjusted or replaced. This stop keeps the inj. rack from shaking at engine idle. It's been awhile since I adjusted one , I think it's a 14mm nut locking down a 12mm adjustment sleeve. Turn it in a little and try it. If you go too far in it will cause some running problems or no start. In that case just back it out, it won't damage anything. I've also seen these wore out and needing replacement but ussually just adjusting them fixes the complaint.
Mr.47
Mar 5, 2014 04:58 AM
ChiefRider
Dec 18, 2011 09:53 PM
steve00
Apr 26, 2010 11:48 AM
bluesky 2008
Apr 28, 2008 02:00 PM
ddjac
Mar 9, 2005 06:13 AM
