sd diesel engines
Old Nov 16, 2006 | 04:13 PM
hapaschold's Avatar
Default sd diesel engines
stupid question perhaps.
90 91 sd sdl diesel engines..... aluminum heads ? blocks ? had discussion with someone saying aluminum blocks also ?
need some light shed on the topic
Old Nov 17, 2006 | 06:49 PM
Charles Munn's Avatar
Default RE: sd diesel engines
ORIGINAL: ForcedInduction
Aluminium head, iron block. The 90-94 300SD/350SD also have the nick name "Rod Bender". They should be avoided at all costs.
If you must have a W126, the 86-87 300SDL is great. If you must have a W140, I suggest the S320.
What about the 86-87 300D T? Don't they too often have a cracked head problem?
Old Nov 20, 2006 | 09:08 PM
mbz300sdl's Avatar
I agree completely with ForcedInduction but have seen 90-91s with a rebuilt or new 3.0 engine. not sure if this is possible with the 140 might be worth looking into if u find a 140 that has bent its rod and needs and engine.
Old Dec 4, 2006 | 11:50 PM
dieselsteve's Avatar
The W140 is an AWESOME car very complex. I have a 1992 300SD that did bend the rods, #1 and 6. I rebuilt the engine over $10K CDN to do EVERY THING and upgrade the rods etc. You can find shops that will do an engine for about $7500-8000 for this engine.
I had a 1987 300SDL great car, a tank, it will go forever. not to complex. the W140 is a very complex car but the ultimate MBZ in my opinion.
Steve
1992 300SD
Old Jan 3, 2007 | 02:52 AM
irishcg's Avatar
I was looking at purchasing a 1992 300SD that has a factory rebuilt 3.5 liter OHC 6-cylinder td engine. Would this be considered a rod-bender?
aa.aunins
May 28, 2009 08:18 AM
pfilips
May 17, 2008 09:22 AM
mnstang
Jan 5, 2006 01:45 AM
ackerman76
Dec 16, 2004 05:37 AM
Jerry
Oct 7, 2004 11:53 PM
