Rear flex disk replacement DIY?
Does anyone have or know where I could find a DIY to replace a rear flex disk on the w201 190e or 190d? I need to replace it because of a clunk and don't know if it's as simple as removing the bolts, removing the disk, then replacing. Any help would be fantastic.
RE: Rear flex disk replacement DIY?
I dunno where you can get the rear only. Does this help you at all?? http://dieselgiant.com/driveshaftandaxle.htm(Scroll down a bit.) 93 bucks for the kit.
