OVP relay question, please help...
Old Dec 21, 2010 | 07:24 PM
danriis's Avatar
Default OVP relay question, please help...
I had the Low Idle and no tach problem and found that it is typically the OVP relay.
I pulled out the OVP, took it apart, resoldered the internal connections, reassembled it and reinstalled.
Problem solved for about a day, then reappeared.
Went ahead and bought another OVP, 'used but tested' and this also did not solve the problem. I put in a new fuse too.
If I plug in the OVP (either one) while the engine is (barely) idling there is a very short return to normal idle, barely noticeable but still noticeable, but then the idle drops back down immediately so low that the engine shakes. I can repeat this over and over, it happens just as the connections are made to the OVP when I plug it in, but the effect is ultra short before the problem reappears.
This has me stumped, any takers?
Thanks in advance,
Dan
Old Jan 17, 2011 | 04:49 PM
danriis's Avatar
Errr...Huh?
mungogerry
Jun 25, 2008 06:14 AM
thewho1971
May 30, 2007 09:23 AM
treefort13
Feb 20, 2007 07:03 PM
amaryakhou
Nov 3, 2006 03:39 AM
Dehaven
Aug 25, 2006 09:39 AM
