Oil cooler hose
Old Aug 13, 2010 | 08:01 PM
wrecks79's Avatar
Default Oil cooler hose
1983 300D turbo diesel. Could someone tell me how much pressure is in the bottom oil cooler line ? Once they start leaking (where the rubber hose connects to metal) do they drip for awhile ? Or rapidly leak till final failure ? Thanks in advance.
Old Aug 14, 2010 | 11:56 AM
wrecks79's Avatar
Thank You. That's what i thought. I must have cracked it when i changed the oil filter houseing gasket. Old and brittle.
What i meant by cracking, is the hose part of the line on the cooler end. When i took the line off of the filter houseing i took the brakets off of the lines so i could move the lines back out of the way, i should have just loosend them and just moved the lines back just far enough to clear the houseing, but i pushed em to far and cracked the old brittle hose. I found this on ebay, think it's any good ? http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
paul060266
Dec 1, 2011 12:02 PM
holdhands
Sep 18, 2010 05:25 PM
300tdgen
Oct 11, 2005 11:50 PM
benztiller
Sep 18, 2005 06:24 AM
300tdgen
Sep 8, 2005 01:15 AM
