New to diesel engine
Old Mar 27, 2009 | 11:03 AM
Coach's Avatar
Default New to diesel engine
1983 mercedes diesel 300sd turbo: After starting the car, the engine sounds rough at idle , but once i rev the engine it goes away... This happens only when the engine is at idle , when i am running, it is smooth running.
Does anyone have any ideas how i can improve this on my car... ?
Old Mar 27, 2009 | 11:33 AM
barrylndn's Avatar
Default Two things...
First - have the valves adjusted (could cost from $150 from a good benz mechanic to upwards of $300 at your local MB Dealer).
Second, find a diesel shop that is authorized to work on Bosch injectors, pull them out, and have them check them. They will check pattern, and the 'pop' pressure to see if they're in spec. Locally, they charge $2 an injector to check them - takes them about a minute a piece, so it shouldn't be much.
That's just my opinion though.
mercedesdieselpetr
Apr 1, 2015 09:13 PM
vegasmadness
Oct 28, 2008 03:23 PM
milner351
Jun 20, 2008 12:36 PM
Dallas 300SDL
Nov 17, 2007 01:34 PM
