In need of help and a 1980 300 sd Vacuum system diagram
Old 09-27-2005 | 12:53 AM
Walter Marria's Avatar
Default In need of help and a 1980 300 sd Vacuum system diagram
I am in need of a 1980 30sd vaccum system diagram, any help? I lose power air and cooling doesn't work. traced every line possible to locate the leak to no avail. won't cut off after it runs for awhile. I believe I have solve that problem. If I can locate the vacuum diagram, I know I could solve the problem. Any recommendations?
Old 10-02-2005 | 09:15 PM
bender's Avatar
Default RE: In need of help and a 1980 300 sd Vacuum system diagram
Walter, I found a book/magazine called "Performance products for your Mercedes Vehicle" They have good diagrams of the vacum system. Their number is 1-800-243-1220- It was $5.
Old 10-02-2005 | 10:25 PM
Benzbob's Avatar
Try using these links for a vac diagram.. http://mb.braingears.com/ http://skinnerbox.steaky.org/Service/Library.html
SunDance1
08-31-2014 10:54 AM
mariaml320
08-05-2007 04:30 PM
mariaml320
07-25-2007 05:25 PM
missoni
07-18-2006 07:33 PM
chaz13
05-10-2004 01:57 PM
