1980 Mercedes 300D vacuum routing diagram
Old Aug 29, 2014 | 09:51 PM
SunDance1's Avatar
Default 1980 Mercedes 300D vacuum routing diagram
Could someone please post a routing diagram? On Vacuum control valve there are several ports. Are they all vacuum ports and interchangeable? Thanks. Ray
Old Aug 30, 2014 | 12:18 PM
SunDance1's Avatar
Thanks for the diagram. It shows that vacuum line goes directly to transmission modulator valve. How does vacuum control valve on top of injector pump affect shifting? From the diagram it seems it is not in the loop. Thanks. Ray
Old Aug 31, 2014 | 09:54 AM
SunDance1's Avatar
So the way I understand it, the vacuum control valve is a bleed valve mechanically linked to throttle. At idle the VCV is closed and vacuum is the same as the break boost line. As you push on gas pedal, the VCV starts leaking vacuum and at full throttle vacuum is zero. This is to mimic a gas engine at idle and under load. If all this is true why would we need the white 3-way valve on top of the valve cover? If there is no EGR, can I disconnect and throw away the white 3-way valve on top of the valve cover?
BIG JOE 40
Jan 26, 2009 07:38 PM
BIG JOE 40
Mar 7, 2008 04:41 PM
mariaml320
Jul 25, 2007 04:25 PM
muso58
Oct 21, 2006 02:24 PM
Walter Marria
Oct 2, 2005 09:25 PM
