MB 87D...STEERING WHEEL OIL???
What is "steering wheel" oil? I'll assume you're referring to power steering fluid? If that is the case, just remove the wingnut on top of the p/s reservoir and pull the cap off to see if it's low on fluid? If it is, top it up( you may as well replace the filter while you are in there as well,the filter is pretty cheap ).
AMGMercedes
Apr 2, 2007 10:49 PM
