Got a question?
Old Aug 20, 2006 | 01:34 AM
Mr.47's Avatar
Default Got a question?
Hi
What are those dots on the side of the speedometer? What its purpose?
please reply
THX.
[IMG]local://upfiles/14627/572C80A35D3D4A38A44E8A2272E4288A.jpg[/IMG]
Old Aug 20, 2006 | 11:27 AM
rwantin's Avatar
Default RE: Got a question?
I have similar marks on my tachometer-less 240D stick. I presume they are max shift points - they seem to fall right where it would be a good idea to shift, or else.
-Robert
Old Aug 20, 2006 | 08:16 PM
Mr.47's Avatar
So that's what its for. But why at the 95 MPH Mark It has one dot? dose that means thats the maximum speed u can go or to down shift to 1st gear? I know that is not good for the engine and transmission.
Please reply
THX
Old Aug 20, 2006 | 11:22 PM
rwantin's Avatar
Never said I shifted at them - at least all the time That's why I said MAX shift points. They seemed to fall in that range. So I did some checking...
My 85-mph speedomer has the following:
One dot: 23 mph
Two dots: 39 mph
Three dots: 65 mph
I also checked the owner's manual. It states: "Do not exceed maximum speed in the individual gears. See line markings on speedometer."
-Robert
Old Aug 20, 2006 | 11:59 PM
Mr.47's Avatar
Since the 3 gear max point is at 65, that means i can travle 65 MPH and below without streessing the engine out and it will give me a bit better gas mile. And can those dots can be used for adjusting auto transmission to shift correctly?
Old Aug 21, 2006 | 12:22 AM
rwantin's Avatar
I think the point was that 65 was not to be exceeded in 3rd - that 65 mph is the maximum speed in third. That is not suggesting that is the best thing for fuel economy. If a car has a 7000 rpm redline, that does not mean you should drive at 7000 rpm.
funkgab
Aug 3, 2009 08:27 AM
heath111
Jul 18, 2009 12:04 PM
Learick
Jan 22, 2008 10:07 AM
C280 wizard
Mar 25, 2006 05:43 PM
DominicanOps
Nov 13, 2005 10:24 PM
