electrical help needed
Old Jun 4, 2009 | 02:07 PM
jimishadow's Avatar
Default electrical help needed
1979 sd headlights work on low beam,,,click to high beam and driver side goes off.bulbs are good.pass side both light.
Old Jun 4, 2009 | 02:27 PM
cycleboy's Avatar
Check your fuses. They are individually fused.
Old Jun 10, 2009 | 05:30 AM
paulactros's Avatar
You might want to check your relays as well not forgetting corrossion of the connectors
Old Jun 10, 2009 | 02:13 PM
gilgorm's Avatar
I am unsure whether you actually switched the passenger bulb to the drivers side to make sure the bulb was not the problem. If you did that already my apologies.
kurnia.2
Feb 11, 2015 03:43 AM
childressj
Apr 20, 2007 06:40 PM
krl
Apr 7, 2007 09:25 PM
soundbud
Mar 4, 2005 05:39 PM
