Buzzing antanna
Old Feb 12, 2007 | 07:54 PM
Mr.47's Avatar
Default Buzzing antanna
Hi
I have a 1984 300SD and while i was driving the antanna made a buzzing sound[sm=smiley13.gif], i checked it and not thingseems to beworng , i tried to removing the radio fuse and nothing works,i even trun off the radio and set the antannain down position and it still makes the sound,couldit bethe motor going out or something else.
Thx
Old Feb 13, 2007 | 03:17 AM
otm646's Avatar
Default RE: Buzzing antanna
buzzing like AM radio or alternator type high pitched whine?
Old Feb 13, 2007 | 01:56 PM
Mr.47's Avatar
Hi
Its like a low buzzing sound. And is there any way to unplug the motor???
Old Feb 13, 2007 | 02:19 PM
AMGMercedes's Avatar
Three possible problems. Either the plastic cog inside theantennadevice has fallen off, the belt has fallen off or the belt has gone bad. When you're inside your trunk, remove or pull away the plastic covering that blocks your acess from getting to the antenna device. On the device, there should be a thick wire(s) connected to it. Pull it offand it should end the buzzing. However, you won't be able to raise or lower the antenna.
If you want to fix the problem, just pop open the antenna device with a screwdriver and inspect the thing for functionality. Mine had a missing cog so I went to the junk yard and got two of them. Works fine now. If you need a belt, PM me and I'll send you one.
Old Feb 13, 2007 | 06:45 PM
Mr.47's Avatar
HI
We figure it out its not the antanna its the sunroof motor, the switch for some reason got stuck to close pos, and now it dont work. Damn.
BStiles
Mar 11, 2009 02:05 PM
mbelle
Jan 10, 2007 01:30 AM
Sean
May 24, 2006 03:55 PM
njudah
Mar 17, 2005 02:52 PM
sdanville
Sep 2, 2004 01:18 PM
