Buying a Merc SD that has been sitting 5 yers. Any tips before craking it over?
Old May 12, 2011 | 04:45 PM
Firpo's Avatar
Default Buying a Merc SD that has been sitting 5 yers. Any tips before craking it over?
Buying my first Merc tomorrow.
It's an 1982 SD turbo.
This thing is clean clean clean, was driving very nicely until it was parked 5 yeras ago, and blocked in a warehouse with 20 BMW motorcycles.
I'm picking it up tomorrow.
I assume to do the usuall, drain and replace the fuel and oil..
Any other tips? Anything to look out for?
Thanks for reading,
Cheers,
aa.
Old May 12, 2011 | 07:28 PM
Firpo's Avatar
Anything other than than?
Rust is not a factor.
It was warehoused, even the exhaust is rust free.
Old May 13, 2011 | 09:17 AM
oldrebuiltdodge's Avatar
Top end lubrication will be an issue, and rust inside the engine, unless it was in a controlled atmosphere IS a major factor. Rust forms when the oil drains off, and isn't replaced. Moisture gets there by the humidity in the air, and condensation due to temprature changes.
Old May 15, 2011 | 07:47 PM
Firpo's Avatar
If rust HAS formed in the top end, really the largest issue is a seize right?
So if there is indeed SOME rust, but it hasn't rusted the piston(s) to the barrel, then it'll probably scrape off and shoot out the exhaust. Is this theory somewhat correct?
Cheers,
aa.
Skrillamonster
Mar 28, 2012 10:25 AM
Skrillamonster
Feb 24, 2012 08:20 PM
Papachristou1177
Jul 26, 2010 09:30 AM
mndwgz
Oct 5, 2008 10:05 PM
ttnguyen23
Apr 16, 2008 02:54 PM
