Amendment to "lift pump" thread
Old Oct 2, 2025 | 02:06 PM
noswendel's Avatar
Default Amendment to "lift pump" thread
I got it wrong. The reason the primer and lift weren't working was because the fuel level in the tank was too low (fuel gauge isn't reliable). I put in a couple gallons, and it started. That brings me to the existing problem.that I had noticed before I had the starting problem. When you start the car, it runs but the idle is extremely rough. If you increase the rpms, it smooths out. The warmer the engine gets the smoother it runs. The car runs normally at increased engine speed. I increased the idle so the idle is smooth but idling too fast (no tach so, I don't know how much). Could this be a weak lift pump? When I was thinking I needed to replace the lift pump, I figured that would solve the idling problem. Any ideas? Thanks.
Old Dec 27, 2025 | 11:02 AM
JustAghost's Avatar
Valve adjustment, compression or injection timing.
Be careful with idle speed. If it goes above 1000rpm it will be uncontrolled and accelerate to maximum speed on its own.
TCBC01
Dec 17, 2010 05:49 PM
steve00
Apr 26, 2010 11:48 AM
kfoot
Feb 18, 2009 08:57 AM
hardhatz
Nov 15, 2005 10:22 AM
rayhalks
Sep 23, 2005 07:57 PM
