98 or 99 Eclass diesel
ORIGINAL: ForcedInduction
They can but why would you want to fill the trunk of such a nice car with homebrew grease?
ORIGINAL: uberwgn
You should make yourself aware of the cost of a replacement fuel pump...just in case
Hello, I just love the idea of B100. I have a E300D 97 with 65K miles. I can get the stuff in Phoenix for the same price, because its subsidised by the gov. 3.00 a gallon. Well I went down there on the way to LA. I filled the tank with the stuff. I drove to LA and everything was just perfect. About half way down on my journey I put some regular diesel into the tank. I got to LA being very proud of my non modified MB running on the B100. The honeymoon was over 48 hours later. I went out to my car and I had a pretty good leak. I took it to HB Benz and they removed my intake manifold and removed all of these bullSxxt plastic cliped gas lines. They also replace shutoff valve and some other bits. Cost me 400 bucks. The nighmare was not over. 1 week later I removed the top intake myself and replaced all the rubber return lines to all 6 cyl. Each one of these reseviors was full of diesel. I believe the plastic gas lines were suspect and all the other parts were shotgun replaced, as they missed these returns. I am now very gun shy (wallet shy) of running on this stuff. I think the stuff will eat rubber, Why else would all 6 rubber return lines fail at the same time?
I have run my 99 turbodiesel on homebrew for two years. I do not wash the fuel so I don't worry about water. The trick is to let it settle for at least a week. I never have had the filter in the car plug up. The car runs great, no smoke that I can see, and the smell is much less bothersome to most people. My fuel is made from cooking oil and chicken fat.
I am doing what is best for my car. There is no sulfur in the fuel and it has at least 10 times the lubrication value. I run everything through a 5 micron filter when pumping it into the car. I have saved about $4000 on fuel so far so I am pinching dollars at this point. I only invested $300 in equipment to do this.
I have 3 cars running on this fuel and have not had a problem. The engine in the 210 runs so quite that it is hard to tell it's diesel.
AMG\\\
Jun 24, 2003 05:30 PM
